unserialize - [internal], line ??
FileEngine::read() - CORE/cake/libs/cache/file.php, line 190
Cache::read() - CORE/cake/libs/cache.php, line 362
DataSource::__cacheDescription() - CORE/cake/libs/model/datasources/datasource.php, line 475
DataSource::describe() - CORE/cake/libs/model/datasources/datasource.php, line 278
DboMysqlBase::describe() - CORE/cake/libs/model/datasources/dbo/dbo_mysql.php, line 120
Model::schema() - CORE/cake/libs/model/model.php, line 938
Model::setSource() - CORE/cake/libs/model/model.php, line 789
Model::__construct() - CORE/cake/libs/model/model.php, line 483
ClassRegistry::init() - CORE/cake/libs/class_registry.php, line 142
Model::__constructLinkedModel() - CORE/cake/libs/model/model.php, line 667
Model::__createLinks() - CORE/cake/libs/model/model.php, line 638
Model::__construct() - CORE/cake/libs/model/model.php, line 491
Warning (2): unserialize() [function.unserialize]: Extra data starting at offset 858 of 1728 bytes [CORE/cake/libs/cache/file.php, line 190]
Controller::loadModel() - CORE/cake/libs/controller/controller.php, line 634
Controller::constructClasses() - CORE/cake/libs/controller/controller.php, line 501
Dispatcher::_invoke() - CORE/cake/dispatcher.php, line 186
Dispatcher::dispatch() - CORE/cake/dispatcher.php, line 171
Warning (2): unserialize() [function.unserialize]: Extra data starting at offset 2 of 16 bytes [CORE/cake/libs/cache/file.php, line 190]
DataSource::listSources() - CORE/cake/libs/model/datasources/datasource.php, line 237
DboMysqli::listSources() - CORE/cake/libs/model/datasources/dbo/dbo_mysqli.php, line 146
Model::setSource() - CORE/cake/libs/model/model.php, line 777
[main] - APP/webroot/index.php, line 86
Warning: unserialize() [function.unserialize]: Extra data starting at offset 2 of 16 bytes in /data/5/2/52a1d110-84e0-4abc-bf28-7b380ca35791/opelclub.sk/web/cake/libs/cache/file.php on line 190
Warning (2): unserialize() [function.unserialize]: Extra data starting at offset 2 of 2818 bytes [CORE/cake/libs/cache/file.php, line 190]
DboMysqlBase::describe() - CORE/cake/libs/model/datasources/dbo/dbo_mysql.php, line 155
Warning (2): unserialize() [function.unserialize]: Extra data starting at offset 614 of 1240 bytes [CORE/cake/libs/cache/file.php, line 190]
ClassRegistry::init() - CORE/cake/libs/class_registry.php, line 150
AppController::loadSettings() - APP/controllers/app_controller.php, line 317
AppController::beforeFilter() - APP/controllers/app_controller.php, line 17
PagesController::beforeFilter() - APP/controllers/pages_controller.php, line 14
Controller::startupProcess() - CORE/cake/libs/controller/controller.php, line 521
Dispatcher::_invoke() - CORE/cake/dispatcher.php, line 187
PagesController::show() - APP/controllers/pages_controller.php, line 58
Dispatcher::_invoke() - CORE/cake/dispatcher.php, line 204
Jednoducho náhoda - E16NZ - OpelClub Slovensko
V jeden obyčajný deň som sa rozhodol napojiť môjho tátoša. Dokotúľal som sa na pumpu a natankoval. Chcem naštartovať motor a ten si povedal dosť, "zdochol" :-) Opäť je vynovatý benzín? Všetky možné kontroli nenašli vinníka - sviečky v poriadku, iskra dobrá, benzínové čerpadlo aj vstrekovacie trysky pracujú, rozvodový remeň je celý... Pri pozornejšej obhliadke cievky zapaľovania,bolo vydieť na nej stopy vysokonapäťového výboja. Napriek tomu, iskra pri vyzuálnej kontrole bola v poriadku. Už som bol zúfalý,po dlhšej dobe som sa rozhodol vymeniť cievku zapaľovania,už som nevedel do čoho "pichnúť"...a hľa motor naskočil.Pritom to nebol prvý takýto prípad. Čo z toho vychádza? Niekedy žiadna nacvičená teória nenahradí praktické skúsenosti.Takže pozor na cievku…
Obr.1
include - APP/views/themed/2015/pages/show.ctp, line 124
View::_render() - CORE/cake/libs/view/view.php, line 736
View::render() - CORE/cake/libs/view/view.php, line 431
Controller::render() - CORE/cake/libs/controller/controller.php, line 908
Dispatcher::_invoke() - CORE/cake/dispatcher.php, line 207
(default) 17 queries took 0 ms
Nr
Query
Error
Affected
Num. rows
Took (ms)
1
SHOW FULL COLUMNS FROM `menuitems`
13
13
0
2
SELECT CHARACTER_SET_NAME FROM INFORMATION_SCHEMA.COLLATIONS WHERE COLLATION_NAME= 'utf8_slovak_ci';
1
1
0
3
SELECT `Setting`.`title`, `Setting`.`content` FROM `settings` AS `Setting` WHERE 1 = 1
1
1
0
4
SELECT `Page`.`id`, `Page`.`content`, `Page`.`highlight_content`, `Page`.`highlight_url`, `Page`.`created`, `Page`.`modified` FROM `pages` AS `Page` LEFT JOIN `users` AS `User` ON (`Page`.`user_id` = `User`.`id`) LEFT JOIN `categories` AS `Category` ON (`Page`.`category_id` = `Category`.`id`) WHERE `Page`.`is_highlight` = 1 AND `Page`.`status` != 3 ORDER BY `Page`.`modified` desc
8
8
0
5
SELECT `Attachment`.`id`, `Attachment`.`name`, `Attachment`.`saved_name`, `Attachment`.`type`, `Attachment`.`size`, `Attachment`.`created`, `Attachment`.`modified`, `AttachmentsPage`.`id`, `AttachmentsPage`.`page_id`, `AttachmentsPage`.`attachment_id` FROM `attachments` AS `Attachment` JOIN `attachments_pages` AS `AttachmentsPage` ON (`AttachmentsPage`.`page_id` IN (274, 257, 261, 258, 256, 198, 195, 197) AND `AttachmentsPage`.`attachment_id` = `Attachment`.`id`)
0
0
0
6
SELECT `Menuitem`.`id`, `Menuitem`.`menu_id`, `Menuitem`.`title`, `Menuitem`.`url`, `Menuitem`.`parent_id`, `Menuitem`.`lft`, `Menuitem`.`rght`, `Menuitem`.`status`, `Menuitem`.`emph`, `Menuitem`.`is_category_list`, `Menuitem`.`sort`, `Menuitem`.`created`, `Menuitem`.`modified`, `Menu`.`id`, `Menu`.`title`, `Menu`.`status`, `Menu`.`created`, `Menu`.`modified` FROM `menuitems` AS `Menuitem` LEFT JOIN `menus` AS `Menu` ON (`Menuitem`.`menu_id` = `Menu`.`id`) WHERE `Menuitem`.`menu_id` = 2 AND `Menuitem`.`status` != 3 ORDER BY `Menuitem`.`sort` asc
8
8
0
7
SELECT `Category`.`id`, `Category`.`title`, `Category`.`status`, `Category`.`parent_id`, `Category`.`show_in_menu`, `Category`.`lft`, `Category`.`rght`, `Category`.`created`, `Category`.`modified`, `Category`.`id_old` FROM `categories` AS `Category` WHERE `Category`.`status` != 3 AND `Category`.`show_in_menu` = 1
5
5
0
8
SHOW FULL COLUMNS FROM `adpositions`
9
9
0
9
SHOW FULL COLUMNS FROM `advertisements`
13
13
0
10
SELECT `Adposition`.`id`, `Adposition`.`title`, `Adposition`.`comment`, `Adposition`.`position_width`, `Adposition`.`position_height`, `Adposition`.`ad_width`, `Adposition`.`ad_height`, `Adposition`.`visible_ads_count`, `Adposition`.`status` FROM `adpositions` AS `Adposition` WHERE `Adposition`.`status` = 1
2
2
0
11
SELECT `Advertisement`.`id`, `Advertisement`.`adposition_id`, `Advertisement`.`partner_id`, `Advertisement`.`valid_from`, `Advertisement`.`valid_to`, `Advertisement`.`saved_filename`, `Advertisement`.`alt`, `Advertisement`.`url`, `Advertisement`.`status`, `Advertisement`.`display_count`, `Advertisement`.`click_count`, `Advertisement`.`created`, `Advertisement`.`modified` FROM `advertisements` AS `Advertisement` WHERE `Advertisement`.`valid_from` <= '2025-04-04 10:14:43' AND `Advertisement`.`valid_to` >= '2025-04-04 10:14:43' AND `Advertisement`.`status` = 1 AND `Advertisement`.`adposition_id` IN (4, 5) ORDER BY RAND() ASC
0
0
0
12
UPDATE `advertisements` AS `Advertisement` LEFT JOIN `adpositions` AS `Adposition` ON (`Advertisement`.`adposition_id` = `Adposition`.`id`) SET `Advertisement`.`display_count` = Advertisement.display_count + 1 WHERE `Advertisement`.`id` IS NULL
0
0
13
SELECT `Page`.`id`, `Page`.`category_id`, `Page`.`page_type`, `Page`.`layout_id`, `Page`.`title`, `Page`.`content`, `Page`.`status`, `Page`.`is_highlight`, `Page`.`highlight_content`, `Page`.`highlight_url`, `Page`.`user_id`, `Page`.`vip_only`, `Page`.`created`, `Page`.`modified`, `Page`.`view_count`, `Page`.`old_author_id`, `User`.`id`, `User`.`user`, `User`.`password`, `User`.`pwd_old`, `User`.`status`, `User`.`name`, `User`.`nickname`, `User`.`email`, `User`.`admin`, `User`.`partner_id`, `User`.`created`, `User`.`modified`, `Category`.`id`, `Category`.`title`, `Category`.`status`, `Category`.`parent_id`, `Category`.`show_in_menu`, `Category`.`lft`, `Category`.`rght`, `Category`.`created`, `Category`.`modified`, `Category`.`id_old` FROM `pages` AS `Page` LEFT JOIN `users` AS `User` ON (`Page`.`user_id` = `User`.`id`) LEFT JOIN `categories` AS `Category` ON (`Page`.`category_id` = `Category`.`id`) WHERE `Page`.`id` = 74 AND `Page`.`status` = 1 LIMIT 1
1
1
0
14
SELECT `Attachment`.`id`, `Attachment`.`name`, `Attachment`.`saved_name`, `Attachment`.`type`, `Attachment`.`size`, `Attachment`.`created`, `Attachment`.`modified`, `AttachmentsPage`.`id`, `AttachmentsPage`.`page_id`, `AttachmentsPage`.`attachment_id` FROM `attachments` AS `Attachment` JOIN `attachments_pages` AS `AttachmentsPage` ON (`AttachmentsPage`.`page_id` = 74 AND `AttachmentsPage`.`attachment_id` = `Attachment`.`id`)
0
0
0
15
UPDATE `pages` AS `Page` LEFT JOIN `users` AS `User` ON (`Page`.`user_id` = `User`.`id`) LEFT JOIN `categories` AS `Category` ON (`Page`.`category_id` = `Category`.`id`) SET `Page`.`view_count` = Page.view_count + 1 WHERE `Page`.`id` = 74
1
0
16
SELECT `Category`.`lft`, `Category`.`rght` FROM `categories` AS `Category` WHERE `Category`.`id` = 15 LIMIT 1
1
1
0
17
SELECT `Category`.`id`, `Category`.`title` FROM `categories` AS `Category` WHERE 1 = 1 AND `Category`.`lft` <= 29 AND `Category`.`rght` >= 30 ORDER BY `Category`.`lft` asc
1
1
0
(forum) 4 queries took 0 ms
Nr
Query
Error
Affected
Num. rows
Took (ms)
1
SHOW FULL COLUMNS FROM `phpbb_posts`
29
29
0
2
SELECT CHARACTER_SET_NAME FROM INFORMATION_SCHEMA.COLLATIONS WHERE COLLATION_NAME= 'utf8_bin';
1
1
0
3
SELECT CHARACTER_SET_NAME FROM INFORMATION_SCHEMA.COLLATIONS WHERE COLLATION_NAME= 'utf8_unicode_ci';
